New Plumbing Now Hot Water Runs Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2008, 04:23 PM   #1
Hi all,
Just redid the plumbing in my house, I have a well so I ran 1 inch copper from the well pressure tank to a manabloc system. From there I fed 3/4 inch Pex to the oil boiler domestic coil (it was originally 1/2 inch copper) and 3/4 inch Pex back to the manabloc. Feeds off the manabloc are 1/2 inch.
Before I was able to take a 30 minute shower without running out of hot water. Now the hot water runs out after only a few minutes. Becasue the domestic coils are heat on demand the only thing I can think of is that the 3/4 inch tubing is passing more water through then it can heat up reliably.
Is there any simple way to fix this?
RekrAMD is offline   Reply With Quote
Old 07-07-2008, 10:21 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You need some type of flow control device on the outlet I think. On demand hot water heaters if you read up about them have limeted flow rates of ~ 5-8 GPM due to the same issue I believe you're talking about.
Journeyman Plumber
Old 07-07-2008, 11:49 AM   #3
You might try a water saver shower head. How do you take a 30 min. shower. Must be a big man or have company in the shower.
BillyD is offline   Reply With Quote
cold water runs hot phxhouser Plumbing 4 06-11-2008 10:03 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
PVC Pipes Pop And Click When Water Runs jasonsullivan Plumbing 3 01-16-2008 03:41 PM
Hot water runs out quickly Thirdeye Plumbing 9 06-03-2007 01:05 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
