-   -   New Plumbing Now Hot Water Runs Out (http://www.diychatroom.com/f7/new-plumbing-now-hot-water-runs-out-23254/)
RekrAMD 07-06-2008 04:23 PM
Hi all,
Just redid the plumbing in my house, I have a well so I ran 1 inch copper from the well pressure tank to a manabloc system. From there I fed 3/4 inch Pex to the oil boiler domestic coil (it was originally 1/2 inch copper) and 3/4 inch Pex back to the manabloc. Feeds off the manabloc are 1/2 inch.
Before I was able to take a 30 minute shower without running out of hot water. Now the hot water runs out after only a few minutes. Becasue the domestic coils are heat on demand the only thing I can think of is that the 3/4 inch tubing is passing more water through then it can heat up reliably.
Is there any simple way to fix this?
Alan 07-07-2008 10:21 AM
You need some type of flow control device on the outlet I think. On demand hot water heaters if you read up about them have limeted flow rates of ~ 5-8 GPM due to the same issue I believe you're talking about.
BillyD 07-07-2008 11:49 AM
You might try a water saver shower head. How do you take a 30 min. shower. Must be a big man or have company in the shower.
