Old 04-19-2010, 08:27 AM   #1
New plumbing
New plumbing to be done in a remodel.
I have had different opionions on whether to use 3" or 4" PVC drain pipes. is the 4 really less likely to clog considering the toilet trap is 3" inch? There will be one vent pipe going to the roof for master bath, 1/2 bath and kitchen.
Cost of material is not the issue, but using the smaller 3" would be easier to bury in the walls. Just hate not to use the best long term materials.
sharp is offline   Reply With Quote
Old 04-19-2010, 09:54 AM   #2
New plumbing
Sometimes, bigger is not better. If there is not enough water drainage, the solids could stop in the pipe. Most houses I have plumbed have 3" until it goes through the foundation wall, and then goes to 4". This depends on local codes though.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-19-2010, 10:06 AM   #3
Doing it myself
Alan's Avatar
New plumbing
The toilet TRAP should not be 3" Most are 2" 2-1/8 or 2-1/2.
The drain line is a 3" minimum, however, by water conservation standards today, you will have a lot more issues if you install a 4" drain, due to the fact that a 4" drain needs more water per flush to 'float the solids down the line'
With todays toilets, you are getting less and less water per flush.
Journeyman Plumber
Old 04-19-2010, 10:45 AM   #4
New plumbing
Alan. Toilet traps are a part of the toilet bowl, not a separate part. The minimum size of piping under the toilet is 3'. There should be no trap in the piping under the toilet. Not sure why you brought up the word trap since it was not in the original post. Maybe I am just a bit confused about your answer.
Old 04-20-2010, 09:55 AM   #5
Doing it myself
Alan's Avatar
New plumbing
It was in the original post. Please Re-read.
"is the 4 really less likely to clog considering the toilet trap is 3" inch?"
What I meant to say was that the toilet trap shouldn't be 3" since there isn't a trap in the drainage piping. I guess I probably would have been better off actually just saying that there shouldn't be a trap on the toilet line. I've been plumbing for 3 years now, I definitely know better.
Journeyman Plumber
Old 04-20-2010, 11:04 AM   #6
New plumbing
Alan, my apologies after re-reading the post. I actually missed it twice. Sometimes I forget that the people asking advice, use wording that is actually inaccurate, at least I hope he doesn't have a trap in the toilet drainline. 35 years in the trade, over 10,000 posts in DIY sites and retired and still miss some things.
Old 04-21-2010, 08:25 AM   #7
New plumbing
Thanks for the replies. I going to go with 3" drains
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 08:55 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
How to find plumbing distributors for plumbing invention? Timster Plumbing 7 05-20-2009 02:53 AM
