New P Trap - Any Feedback? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2011, 05:13 PM   #1
new P trap - any feedback?
I found a newly invented P trap, with an exterior knob that sweeps through the trap and clears out clogs. It also allows you to catch an article that falls into the drain. It is clear plastic, so you can see the water draining through - like the view of those clear plastic ant farms!
Anyone have one of these, and what is your experience over the long term? Does the plastic hold out? Does the rotating knob stay watertight?
Fredericch
fredericch is offline   Reply With Quote
Old 09-21-2011, 06:39 PM   #2
Rewards Points: 150
At 4 times the cost I would just undo the reg. trap.
josall is offline   Reply With Quote
Old 09-21-2011, 06:39 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
Sounds like a solution looking for a problem.
1. "Sweep"? Sounds like a point for water to leak out.
2. How often do you have a p-trap get cloged?
We have been in our house 11 years....I have yet to have a blockage of the p-trap. One of the advantages of ABS plumbing is that it does stuff does not stick to it as well.....
I think it's better to prevent blockage......dont' throw that crap down the sink.....that is what sink filters are for....
ddawg16 is online now   Reply With Quote
Old 09-21-2011, 07:06 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 676
Agreed. The purpose of a trap is to prevent sewer gases from entering your home. Nothing but liquid should go down it.
I think those spinner traps belong on the same shelf with the miracle putty
Old 09-21-2011, 11:51 PM   #5
I've seen those at the big boxes and my first instinct was to cringe thinking about how much more quickly it would clog when hair, etc... gets caught in that little wheel inside the trap.
VIPlumber is offline   Reply With Quote
Old 09-22-2011, 08:37 AM   #6
Rewards Points: 3,130
Nothing I'd ever use. If you're concerned about clogging traps, get the kind with a removable plug for easier cleaning.
Old 09-22-2011, 09:39 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
P-traps approved with UPC stamps are designed to be self cleaning. Hence, that p-trap is illegal.
Enough said.
Journeyman Plumber
Old 09-22-2011, 02:14 PM   #8
self-cleaning?
Enough said.
How does a P-trap clean itself? Just curious.
Fredericch
Old 09-22-2011, 03:54 PM   #9
Plumber
Rewards Points: 676
When a p trap is properly sized it is considered self cleaning
Tags
p trap , rotating
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
