New Moen Faucet Hot Water Low Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2012, 07:18 PM   #1
New Moen faucet hot water low pressure
Hello everyone.
I've been doing some upgrading to my kitchen lately. 2 weeks ago, I installed a new Moen 7840 Camerist faucet. Its a single handle with a side sprayer.
After I installed it, pressure was fine. Then last weekend, I installed a new dishwasher and a new garbage disposal. After that, the pressure on the hot side is much lower than the cold side. The same thing happens when the side sprayer is in use also.
Pressure elsewhere in the house is fine.. I never touched my hot water heater.
Plumbing is copper.
I'm looking for things to check/try any ideas?
derwood5555 is offline   Reply With Quote
Old 02-24-2012, 07:23 PM   #2
Rewards Points: 13,458
I would not be surprized that it was just trash that came loose in the lines stuck in the valve assembly.
Old 02-24-2012, 08:58 PM   #3
OK, so I just need to take the compression fitting off and see if I can get it cleaned out? I've never really dealt with a faucet before.
Old 02-24-2012, 09:43 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It could also be that the washer in your angle stop came loose and lodged itself somewhere it shouldn't be.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (02-24-2012)
Old 02-24-2012, 11:01 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is valve under sink closed/clogged?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-25-2012, 03:01 PM   #6
I'll turn things back off this weekend and see if I can see whats going on.
How do I check the angle valve?
Thanks for the ideas.
Old 02-25-2012, 03:05 PM   #7
Shut off the water disconnet the line under the sink and put it in a bucket and turn the valve back on.
Low Pressure from Moen faucet tsperry Plumbing 1 12-08-2011 05:11 AM
Kitchen faucet low water pressure apt238 Plumbing 4 05-04-2011 03:38 PM
cold water pressure low in new faucet tndale Plumbing 1 03-16-2011 02:15 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
