New Moen Cartridge Is Still Leaking On Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 12:46 AM   #1
New Moen Cartridge Is Still Leaking on Bathtub faucet
I replaced Moen new cartridge on bathtub faucet but it still leaking. I cleaned the inside of the pipe where the cartridge seats but doesn't help. the leaking is the same as the old cartridge (see picture of the cartridge). Don't know why? Is it the cartridge itself the quality problem? If it can't be fixed by replacing the cartridge so I have to get the whole set of bathtub faucet (including the shower head over the bathtub) and cut the pipe, solder the new set of faucet pipe. That's a big project and cost more.
Dose any body know what's that problem and how to solve this leaking problem without changing the whole set of bathtub faucet (without cutting the pipe and soldering a new one)? Thanks.
rliu is offline   Reply With Quote
Old 11-18-2012, 05:51 AM   #2
DIY staff
Rewards Points: 7,174
Examine the inside of the valve body---sometimes a bit of rubber from the old cartridge gets stuck to the opening.
Light sand paper to clean---
If it leaks after that----bad cartridge----call Moen---they have a very good help line and often send free parts----
Old 11-18-2012, 10:38 AM   #3
I have cleaned and sanded the inside of the valve body, nothing there. It is still leaking with the new cartridge replaced.
Should I have to replace the valve body, cut the old one and re-solder the new valve body?
Old 11-18-2012, 11:53 AM   #4
Rewards Points: 1,646
If the new cartridge is from Moen, I'd call and ask for a replacement.
If from a store, return and get a new one to try.
New one might work and would save a ton of work and $ IMO.
bob22 is offline   Reply With Quote
Old 11-19-2012, 12:31 AM   #5
Thanks, I'll try to change another one. The leak is from the bottom faucet not from the valve itself (handle). Don't know what's wrong, it should be the problem inside of valve.
Old 11-19-2012, 06:03 AM   #6
DIY staff
Dribb;ing for a minute from the spout is normal --if it stops after a minute----some times water trapped in the shower riser and spout pipe take a minute to drain out---
Old 01-13-2013, 08:53 PM   #7
I bought another new cartridge and solved the problem. So sometimes some new parts are still not good enough. thanks all.
The Following User Says Thank You to rliu For This Useful Post:
oh'mike (01-14-2013)
Old 01-14-2013, 08:49 AM   #8
Roofmaster
Rewards Points: 2,210
Amazing, bad right out of the box. What is this country coming to? QC, Moen???
Tags
bathtub faucet leaking , moen faucet , plumbing
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Faucet leaking on tub, could just be cartridge? GordCooper Plumbing 6 02-16-2012 03:45 PM
How Do I Remove A Moen Shower Faucet Cartridge kgkings Plumbing 23 10-11-2011 06:08 AM
Bathtub faucet leaking majas Plumbing 3 09-25-2011 10:04 AM
how to recognize the new or old bathtub faucet cartridge jeand Plumbing 2 12-18-2010 01:27 PM
