New Moan Valve Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2013, 11:12 PM   #1
Trucon01's Avatar
Rewards Points: 510
New Moan valve help
Hi All,
I just baught a new Moan setup for my shower. I have the level in the off position, but water still comes out the top. Granted, I don't have the pipe from the valve to the shower head connected, but that shouldn't matter. Water should stop at the valve?
What am I doing wrong?
PS -- The valve is in the right direction and says UP on the top of the brass
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-28-2013, 06:20 AM   #2
DIY staff
Rewards Points: 7,174
I never had that problem-----Get that top pipe on so you can control the flow---remover the plastic handle and turn the shaft by hand---see what position stops the flow---
Old 02-28-2013, 07:46 AM   #3
Trucon01's Avatar
Rewards Points: 510
I'll give that a try when I get home tonight.
The Following User Says Thank You to Trucon01 For This Useful Post:
oh'mike (02-28-2013)
Old 02-28-2013, 09:28 PM   #4
Trucon01's Avatar
Rewards Points: 510
Good news, I got the value to shut off. I just attached the pipe to the flange elbow and used the wrench to find the right spot. Thanks for that!!
Now I need some tricks of the trade... I followed the directions about the placement of the valve but I still seem to be too far out. I used 1/2 drywall just as a guide and as you can see, the level is pretty far away from where the plate would go.
Is there an easy way to determine the right placement of the valve? Should I just go get my cement board and tile, put that against the wall and move the valve accordingly or is there an easier / better way?
Old 02-28-2013, 10:50 PM   #5
moen valves used to come with a plastic plate that you left screwed to the valve and the face of that plate was the finished wall surface. you also cut the drywall or cement board and tile around it so the plate would fit on. read the instructions.
Old 02-28-2013, 11:18 PM   #6
Hard to tell from that picture. To me it looks like cover plate is flat against drywall. I usually set mine farther back because you can always use the handle extenders. The directions are poor at best. Cut your plastic pipes and use some elbows over, sawzall the screws in your mounting board and push everything back into the wall. Use that plastic cover piece I think it sets 1/4 inch from the face of the plaster ground. Yeah, I think that was what they called it, the plaster ground, that makes sense -yeah.
paintdrying is offline   Reply With Quote
Old 03-01-2013, 12:09 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 358
+1
Put the plaster ring back on set the face of it to finished wall. Instructions are right on it
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 08:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 04:04 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
