New Member Dual Head Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 08:52 PM   #1
New member dual head question
I have searched the threads and have seen some information dancing around what is needed for installing two shower heads but here is what I haven't gotten a good answer on. I know I will need 3/4 supply lines but I want to be able to simply split the supply lines in the bathroom to the two shower heads. Is it better to independently control the heads since they won't be used at the same time all the time or do you control the temp in one spot and have a shut off valve for each head...I think I'm starting to confuse myself. What is the minimum I would need to get the job done? Thanks in advance for any help
Mook99ta is offline   Reply With Quote
Old 01-27-2013, 10:18 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
couple ways you can do it one master control on off both heads 2 independent controls one for each head or a single control with two Independence shut offs for each head. the piping can get tricky depending which way you go. most common set up is master temp control with 2 independent on and off valves for each head, only thing temp will be the same at both heads.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-27-2013, 10:22 PM   #3
Rewards Points: 14,294
Google "Three way shower deverter valve"
building a bulk head question??? ryan5068 Building & Construction 4 05-20-2010 03:20 PM
Question about pressure and low-flow showerheads. IckesTheSane Plumbing 4 05-04-2010 07:21 PM
New Member with a Sink question LisaLo6 Plumbing 3 07-17-2008 12:03 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
New member with question ricgail Introductions 2 11-15-2006 04:28 PM
