New Lead Toilet Riser - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2012, 07:16 PM   #1
New lead toilet riser
I am installing a toilet on a new basement rough-in. The riser is 4'' lead (yes, it really is lead) and sticks up a good 5''; and is set in very level concrete. What should I do about a attaching a flange? Should I anchor a brass flange to the cement, peen over the lead and solder/wipe to join them, or is there a more appropriate solution? The finished floor will be less than an inch above the concrete. Here might be a picture, for what it is worth:
http://www.diychatroom.com/members/r...138135/albums/
Thank you very much for your help,
Brian
rutnip is offline   Reply With Quote
Old 01-01-2012, 07:27 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by rutnip View Post
I am installing a toilet on a new basement rough-in. The riser is 4'' lead...
where is a new rough in done with lead?
Old 01-02-2012, 07:20 AM   #3
Montreal. Surprising, isn't it?
Old 01-11-2012, 09:39 AM   #4
Can anyone suggest a forum where my question might be answered?
Old 01-11-2012, 10:26 AM   #5
MarginallyQualified
I've never once worked with lead pipe.
I think I've see it installed maybe twice.
What I've learned about it is to either leave it alone...
or change it out altogether.
That folk wisdom may or may not apply in Montreal.
Rather than a forum... you need to find some grizzled old plumber.
Go to a supply house or a LONG established plumbing company and ask for one
or look for the geezer chain smoking in the corner.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
rutnip (01-11-2012)
Old 01-11-2012, 12:55 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Most of the old ones I come across just have the lead folded over the sides like flange and closet bolts anchored into floor,very optimistic to say the least i would say!
I suppose you could bolt a cast iron flange to the floor on top of the lead after you fold it over,then use a good no seep wax ring
plummen is offline   Reply With Quote
Old 01-11-2012, 01:10 PM   #7
Thanks plummen,
My thinking is that it would be better if the lead was on top of the flange; if I bolt a brass flange to the floor I should be able to solder the lead to it.
Old 01-11-2012, 01:19 PM   #8
plummen's Avatar
You could melt some lead and work it in through the bolt holes if you were worried about it i suppose,a no seep wax ring should take care of it though.
I have used lead roof boots to repair lead flanges in the past(you didnt hear that from me though! )
The Following User Says Thank You to plummen For This Useful Post:
rutnip (01-11-2012)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 05:37 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
