New Kohler Tub - Drainplug Not Sealing - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2010, 11:40 PM   #1
Rewards Points: 160
new kohler tub - drainplug not sealing
Installed a few months ago, it's a Mariposa (K1229-LA). Drain plug just twists in to seal and then untwists a little to remain up so water can drain. It's never worked well but now it won't seal at all - the rubber gasket seems to be sticking out around the perimeter of the plug. Checked Kohler website and they don't show a parts diagram or list any replacement parts. Anyone out there familiar with these things? Thanks!
philS is offline   Reply With Quote
Old 06-23-2010, 04:33 PM   #2
Owner
LateralConcepts's Avatar
Sounds like it's just adjusted too high. A lift and turn stopper will have a set screw that holds the (chrome) handle tight against a (brass) shaft under the rubber gasket. They're kinda awkward to reach but, you'll need to loosen the set screw, pull the handle off, then thread the brass piece up or down to the right height. Note before putting the handle back on, you'll notice a flat part on the round brass shaft. Your set screw needs to line up with that.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 06-23-2010, 09:44 PM   #3
Rewards Points: 160
LateralConcepts - Don;t know how but your message got the drain working perfectly, the gasket back in place and its original size. I didn;t have to do a thing. Must be thinking (laterally) outside the box. And now that I know where to look I see the setscrew and so I know how to take it apart, if (when?) the problem reappears. Thanks!
Old 06-24-2010, 08:15 AM   #4
Owner
philS - Haha not sure that I helped, but you're welcome. Glad it's workin' again. Take care!
Lateral
(208) 818-8241
Kohler Stainless Steel Sink Pitting/Rusting RegeSullivan General DIY Discussions 12 01-13-2013 06:54 PM
Kohler whirlpool installation bypass air switch Jet001 Electrical 1 04-29-2010 04:35 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 02:12 PM
sealing up air leaks between troyce1 General DIY Discussions 2 10-15-2008 08:14 AM
