Old 10-27-2012, 09:22 AM   #1
New Kitchen Sink Drain
Before I had my kitchen renovated, my main drain pipe center was 14.5" from the bottom of the cabinet and my garborator output center was 14.5" from the bottom of the cabinet. So there was no problem as the pipes were at the same level.
However.
Now that my sink was replaced with a 'designer' sink, it is 4" lower than the original. That means that my garborator output is 4" lower than my drain pipe. ( which is brass and goes into the wall).
What can I do. How am I supposed to make the water go from the garborator p-trap and travel upwards 4" to the main drain without it coming back up into the garborator.
Dumbfounded171 is offline   Reply With Quote
Old 10-27-2012, 11:01 AM   #2
call me E
TheEplumber's Avatar
You need to lower the drain inside the wall
or remove the disposal
or get a shallower sink
Old 10-27-2012, 11:05 AM   #3
Sometimes I have to abandon the existing drain pipe that is in the wall, and drill a hole through the bottom of the cabinet and run a new drain line. You have to have a crawlspace or basement, and studor vents have to be allowed where you are. You also need to cap off your roof vent and old drain stub out if you can do it like that.
broox is offline   Reply With Quote
Old 10-27-2012, 10:02 PM   #4
That's what I was afraid of. So I removed the garborator. A shame. But it was the cheapest alternative. Thanks again
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 03:37 PM
Leaking drain pipe under kitchen sink dethun Plumbing 20 09-26-2012 08:30 AM
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 09:45 PM
kitchen sink drain hole lucylu092910 Plumbing 1 04-19-2010 09:59 AM
Help: Kitchen sink drain is clogged with grease cips Plumbing 4 08-10-2009 11:11 AM
