New Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2014, 07:28 AM   #1
New kitchen sink
Hello All,
We are redoing out kitchen and will need to replace our double sink. The plumbing is coming from the wall and we are trying are trying to not change any of it. The new subfloor and the new cabinets will add an inch of height. Can we just get a sink that's an inch deeper to make up for the difference?
Thanks A lot!!
yakusoku82 is offline   Reply With Quote
Old 03-28-2014, 07:38 AM   #2
Rewards Points: 144
You should not need to.Don't you have flexible supply lines?You tailpice or trap should have some adjustment to make up the inch.
mako1 is offline   Reply With Quote
Old 03-28-2014, 07:41 AM   #3
Yes, the supply lines are flexible. We were just worried about the drainage pipes.
Old 03-28-2014, 08:09 AM   #4
Rewards Points: 30
You will have no problem. When raising the countertop you may need to purchase a tailpiece extension and if you install a new sink you may have to change some of the drain tubing. All work you can do yourself with no problems. Just do not use any flexible drain piping!
SHR Plumber is offline   Reply With Quote
Old 03-28-2014, 08:23 AM   #5
Thanks everyone for the help!
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Moving kitchen sink teachtech Plumbing 4 08-08-2010 10:13 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
