New Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2011, 07:48 AM   #1
new kitchen faucet
i purchased a new kitchen faucet, that contains flexible water hoses, but they do not reach water valves under the sink. Currently I have copper tubing attached to valves, how do I attach the new faucet to the copper tubes?
dpeet is offline   Reply With Quote
Old 09-25-2011, 08:35 AM   #2
DIY staff
Rewards Points: 7,174
In the brass fitting section at the store --get a 3/8 inch compression coupling--
cut the existing tubing to the correct length with a tubing cutter--attach the coupling t the tube --discard the nut and ferrule on the top and hook up the line.---I'll see if google images has a picture--
Google Image Result for
Lightfoot (09-25-2011)
Old 09-25-2011, 08:39 AM   #3
Lightfoot's Avatar
Rewards Points: 272
what he said^
Lightfoot is offline   Reply With Quote
Old 09-25-2011, 03:30 PM   #4
AlbacoreShuffle's Avatar
Home Depot sells a 3/8" x 3/8" x 20" extention that will hook right up to the faucet supply and then to the shut off valve under the sink.
http://www.homedepot.com/Plumbing-Pl...atalogId=10053
AlbacoreShuffle is offline   Reply With Quote
Outdoor Kitchen and garage faucet plumbing plumlost Plumbing 7 11-09-2014 09:01 AM
kitchen faucet sudden stoppage amakarevic Plumbing 4 08-31-2011 10:47 AM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 12:08 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
