Old 11-11-2007, 07:23 PM   #1
Post
new install shut off valve leaking
Installed 3 new shut off valves solder not compression(required by code). Had no leaks when we turned water on. We opened valves and cleared lines and then reclosed valves, now one is leaking at the handle. Anything we can do besides cutting off and replacing? Thanks
ferris84 is offline   Reply With Quote
Old 11-11-2007, 10:09 PM   #2
Custom Cabinet Maker
YES, just tighten the packing nut under the handle
skymaster is offline   Reply With Quote
Old 11-12-2007, 10:22 AM   #3
If valve was sweated on 'as is', it is possible that gaskets were damaged by heat. When I sweat a gate or globe valves, I disassemble them, and work with just the brass body, and reassemble once it cooled down. Ball valves, I open and wrap a wet rag over them.
I tightening the nut does not work (gaskets damaged), you might need to get a new same exact valve, disassemble, and swap the innards.
scorrpio is offline   Reply With Quote
Old 11-12-2007, 04:47 PM   #4
We had tightened down the packing screw but retried by loosing and retightening this seems to have worked will watch and try the next fix if need to, Thanks again.
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Shut-off valve leaking Keyo77 Plumbing 10 09-10-2007 06:58 PM
leaking stop valve farrington135 Plumbing 1 03-31-2007 07:33 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
