New Install Shower Has Poor Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2008, 04:17 PM   #1
New install shower has poor hot water pressure
I just installed a new Pegasus shower, 9000 series. I replaced all the plumbing going to the device and added a Tee before the shower valve for the hot and cold to feed another set of faucets, I get great pressure from the two lines that tee off. My problem is I get really poor pressure from the hot side of the valve and great pressure from the cold side. I adjusted the limiters, that doesn't help. Any suggestions would be great!!
rwhitne is offline   Reply With Quote
Old 01-20-2008, 12:45 AM   #2
Master Plumber
Rewards Points: 150
Remove the cartridge and see if it is plugged or you can flush the line with the cartridge out.
jpplumber is offline   Reply With Quote
Old 01-20-2008, 04:13 PM   #3
I replaced the cartridge, now good to go. Thanks!!!
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 01:23 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 09:58 AM
No Hot Water Pressure In Shower Randy Stuempfig Plumbing 6 01-02-2008 07:35 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 06:55 PM
