its water, could be for a hose bib or a water line to the dock if you have one. looks like the plumber forgot that one. if the house is new they need to come back and finish it.
if it is a new house you should call the builder and make them fix it or have the plumber fix it. it is soldered on and you would need a torch andyou also have to turn the water off and drain the water out to unsolder it. do not twist it or pull on it. call the builder
thanks so much for responding DannyT. I think you are probably correct.... its probably water. would you recommend (obviously at my own risk ) i try to remove the cap with a pipe wrench to see if water comes out? If so, do you think i'll be able to recap it?
that is soldered on ..needs to be removed by torch ..and fitting soldered bach on ....not pipe wrench.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
