New Hot Water Tank & Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2010, 11:29 AM   #1
Newly Retired
tuchodi's Avatar
I am installing a new gas hot water tank and also going to replace all the copper lines in the house with Pex. My question is can I use Pex right out of the hot water tank or should I use copper to the manifold and then Pex. I am replacing both the hot and cold copper as the lines are corroded and have developed a few pin holes.
tuchodi is offline   Reply With Quote
Old 10-11-2010, 01:43 PM   #2
HVAC / Plumbing
If it requirs an inspection. You will need to ask inspector.. Some here will allow pex right out of the wh some want about 6"-8" of copper comming out of the tank
kenmac is offline   Reply With Quote
Old 10-11-2010, 08:04 PM   #3
Newly Retired
tuchodi's Avatar
Thanks kenmac, yes it will need an inspection so I will check with the inspector. I looked in the building code but there was no mention but the book is 2008.
Old 10-11-2010, 09:03 PM   #4
HVAC / Plumbing
Well, around my parts. Some will go strickly by book some add what they want. I always ask because the inspector ( around here ) has the last word. I will work in 1 city get inspection & all is ok. I go to another city do it the same way & that inspector wants it done differently
Old 10-12-2010, 09:06 AM   #5
Where I'm at (UPC) code book states 18" of pipe off the water heater before PEX can be used
the_man is offline   Reply With Quote
Raising Water Heater Tank doesntmatter Plumbing 6 09-30-2010 09:05 AM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 02:12 PM
Water softener brine tank smell dcgroshek Plumbing 3 06-30-2010 01:09 AM
Tank less water heater bidet vs tank type water heater bidet husband&me Plumbing 4 04-05-2010 10:59 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
