New Hot Water System For A 2 Bed Flat - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2012, 06:28 PM   #1
New Hot Water System for a 2 bed flat
Hello,
I currently have a Gledhill Pulsacoil 2000 water heater in my 2 bed flat and am having countless issues with it and I have decided to get it replaced - but am not sure where to begin.
There is no gas supply in the flat. The heaters are electric and so I do not need a combi boiler, the sole purpose is to heat the water. Good hot water pressure is important. The space does not allow for venting. The mains water pressure is very good.
Any advice would be appreciated.
Mo
Mo2501 is offline   Reply With Quote
Old 05-29-2012, 02:08 AM   #2
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
what countless issues are you having?Is the water heater gas or electric?Or you wanting advice on what type of w/h to install
wctekkk is offline   Reply With Quote
Tags
advice , boiler replacement , hot water heater
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 06:54 AM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
