New Hot Water Heater Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2013, 05:21 PM   #1
new hot water heater problem
Hello all. I recently replaced our hot water heater because the old one was leaking. Now, when showering if the toilet is flushed the shower gets very hot. If the sink is turned on the shower gets cold. We didn't have this problem with the old heater. It was a 38 gal and the new is 50 gal. Any idea what could be causing this? The old one was soldered all the way to the water heater and for the new one I used some flex pipe with shark bites on one end and it screws on the other. Not sure if that makes a difference or not. Any help would be appreciated. Thanks.
bmyer is offline   Reply With Quote
Old 01-19-2013, 05:39 PM   #2
DIY staff
Rewards Points: 7,174
Coincidental failure---the pressure balancing cartridge in the shower needs replacing--
Could be some crud dislodged when the new heater was installed,but I doubt it.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
bmyer (01-21-2013), joecaption (01-19-2013)
Old 01-23-2013, 09:01 PM   #3
Thanks for the reply oh'mike. The shower control is about a 10 year old delta. It has a cup and springs and a ball inside where the newer cartridges would be. I replaced both of those parts, still have the same problem. Is there any way to upgrade this to newer stuff without tearing out the shower? I have no access to the pipes besides the hole in the shower. Thanks.
Old 01-24-2013, 10:16 AM   #4
Rewards Points: 12,878
Need access behind the wall to replace it.
bmyer (01-24-2013)
Old 01-24-2013, 10:22 AM   #5
Roofmaster
Rewards Points: 2,172
If you replaced parts in the shower valve, and you still have the same problem, I would suspect something you did during the install to cut down flow from the heater. Is the cold in valve all the way open?
The Following User Says Thank You to jagans For This Useful Post:
bmyer (01-24-2013)
Old 01-24-2013, 10:52 AM   #6
Rewards Points: 156
You may have disrupted sediment when you swapped out the water heater, and debris could be in your shower faucet, and in the faucet screens. I would disassemble your shower faucet first and clean the guts. Those things are supposed to regulate temperature and pressure to prevent scalding, and if there's gunk in there, it cannot do it's job
av-geek is offline   Reply With Quote
The Following User Says Thank You to av-geek For This Useful Post:
bmyer (01-24-2013)
Old 01-24-2013, 01:56 PM   #7
Thanks for the replys guys. Yes, jagans the cold water valve is all the way on. My neighbor winterizes homes and suggested blowing out the lines. What do you guys think?
Water heater issues?!? NJdan Plumbing 1 06-04-2015 08:42 PM
water heater problem Jeremy Hillary Boob, PhD Electrical 7 01-06-2013 06:08 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
