-   -   new hot water heater problem (http://www.diychatroom.com/f7/new-hot-water-heater-problem-169552/)
bmyer 01-19-2013 05:21 PM
Hello all. I recently replaced our hot water heater because the old one was leaking. Now, when showering if the toilet is flushed the shower gets very hot. If the sink is turned on the shower gets cold. We didn't have this problem with the old heater. It was a 38 gal and the new is 50 gal. Any idea what could be causing this? The old one was soldered all the way to the water heater and for the new one I used some flex pipe with shark bites on one end and it screws on the other. Not sure if that makes a difference or not. Any help would be appreciated. Thanks.
oh'mike 01-19-2013 05:39 PM
Coincidental failure---the pressure balancing cartridge in the shower needs replacing--
Could be some crud dislodged when the new heater was installed,but I doubt it.
bmyer 01-23-2013 09:01 PM
Thanks for the reply oh'mike. The shower control is about a 10 year old delta. It has a cup and springs and a ball inside where the newer cartridges would be. I replaced both of those parts, still have the same problem. Is there any way to upgrade this to newer stuff without tearing out the shower? I have no access to the pipes besides the hole in the shower. Thanks.
joecaption 01-24-2013 10:16 AM
Need access behind the wall to replace it.
jagans 01-24-2013 10:22 AM
If you replaced parts in the shower valve, and you still have the same problem, I would suspect something you did during the install to cut down flow from the heater. Is the cold in valve all the way open?
av-geek 01-24-2013 10:52 AM
You may have disrupted sediment when you swapped out the water heater, and debris could be in your shower faucet, and in the faucet screens. I would disassemble your shower faucet first and clean the guts. Those things are supposed to regulate temperature and pressure to prevent scalding, and if there's gunk in there, it cannot do it's job
bmyer 01-24-2013 01:56 PM
Thanks for the replys guys. Yes, jagans the cold water valve is all the way on. My neighbor winterizes homes and suggested blowing out the lines. What do you guys think?
