NEW HOT WATER HEATER, ELE, What Do You Sug. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2011, 04:43 PM   #1
Rewards Points: 89
NEW HOT WATER HEATER, ELE, what do you sug.
You read the heading...
I had an old hot water baseboard oil hot water source. Replacing it with a new HVAC so i need a new hot water source. I live in Maryland, so I need a good recovery rate for the hard winters.
Water consumption- the home has 3 people. 2 adults and 1 teen. Was looking at a 50-60 gal unit. Electric what do you recommend...
Thanks,
Chip
chipraynor is offline   Reply With Quote
Old 04-19-2011, 01:17 AM   #2
Rewards Points: 410
http://www.marathonheaters.com/consumers.html
High Gear is offline   Reply With Quote
Old 04-19-2011, 08:04 AM   #3
Electrical Contractor
kbsparky's Avatar
Put a solar collector on your roof. Free energy from the sun!
-KB
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
