New Home To Us...Hot Water Runs Out Quick. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2010, 03:43 PM   #1
New Home to us...Hot Water runs out quick.
Hello everyone, new here and new to home ownership. We have a house that was built in 1987, it's 3 bed 1.5 baths. The hot water heater is a GE SmartWater PE40M09AAH 40 Gallon heater that I believe is only about 8 years old.
We notice the hot water seems to work great everywhere except the shower. It seems to run out very very quickly, 5-7 minutes into a shower before you are reaching for the knob to jack the hot water up a little. We're lucky if we can get about 15 minutes of hot water total before the hot is on all the way and its still getting colder or is completely gone.
We don't have any previous home ownership experience so we've never had to fix anything like this and I'm wondering if there's things I can try myself. I'm very mechanically inclined guy so I don't have a problem at least trying something DIY style before calling a plumber.
Thanks for any help & suggestions you can give!
agentphish is offline   Reply With Quote
Old 01-05-2010, 05:01 PM   #2
Try a water saving showerhead. Less gallons per minute = more minutes of hot water
liquidplumber is offline   Reply With Quote
Old 01-05-2010, 05:34 PM   #3
yeah, our shower head is already low flow. we put that in when we moved in.
Old 01-05-2010, 05:39 PM   #4
What is the WH Temp set to ?
Gas, propane or electric ?
Soeone may have turned it down to save$$
Old 01-05-2010, 05:51 PM   #5
It's also possible the bottom element in the water heater is out and you only have half a tank heating.
hayewe farm is offline   Reply With Quote
Old 01-05-2010, 05:52 PM   #6
Rewards Points: 1,580
If google is right, this is an electric water heater. Sounds like one of your elements is likely no good. I believe the lower is usually the one that goes first (someone will confirm).
Try here for specific info:
http://www.bobvila.com/HowTo_Library...ers-F2171.html
bob22 is offline   Reply With Quote
Old 01-06-2010, 08:59 PM   #7
Do something
D'Brie's Avatar
I would not put any money into an eight year old tank, especially a GE. After eight years a tank is usually close to borrowed time. My suggestion is to install a new Bradford-White 50 gallon tank. If you're inclined to think of tankless, talk to a licenced plumber about options. Good luck!
D'Brie is offline   Reply With Quote
Old 01-06-2010, 09:20 PM   #8
I had the same problem and installed a tankless water heater, I am not sure if it is your budget or not. Works great going on three years.
cybertone is offline   Reply With Quote
Old 01-07-2010, 09:22 AM   #9
I have a tankless heater and it works fine for the shower, but I had issues with it when we used it for the kitchen. Installed a conventional electric for the kitchen and it works much better.
It sounds like the bottom element might be bad. They're pretty cheap.
pyper is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
New Plumbing Now Hot Water Runs Out RekrAMD Plumbing 2 07-07-2008 10:49 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
