New H2Ow Tank????????? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2012, 12:01 PM   #1
New H2Ow tank?????????
Hey all!!!!
I purchased a H2ow 14 Gallon Horizontal Pre-Charge Water System Tank from Menards and there is 2 little plastic hook deally sticking out the 1" inlet/outlet???? not sure if you leave this in there or should it have been removed by the factory when assenbled...... also the other end small fitting does not have an air valve installed????? how can it be pre charged with an open 1/8" pipe thread fitting???????? I read the instruction sheet and it said nothing about the little plastic thing....... It did say it was pre charged.....
Skip
Skipbo00 is offline   Reply With Quote
Old 03-18-2012, 12:30 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
COuld you post pics
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-18-2012, 12:32 PM   #3
Originally Posted by Plumber101 View Post
COuld you post pics
No not really I left the tank up at our cottage,,,, about 180 miles away..... I will try and sketch something out a post it....
Old 03-18-2012, 01:58 PM   #4
Rewards Points: 1,418
If the Schrader valve stem is missing from the small air inlet pipe you can buy a replacement stem from an auto parts store. Also a little wrench to screw it in with. Some auto and bike tire valve stem caps have the wrench tip built into them.
But it will be difficult to pressurize the tank using this inlet unless it is in the form of a protruding stud on which a pump air hose can be pressed onto (the Schrader valve stem fits into the stud.)
You can also screw an assembly of pipes with a small faucet like valve into the tank's air inlet instead of a Schrader valve stem. You would select pieces to make up the assembly so the last piece is something that you press the pump hose onto.
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
H2ow Pressure tank Tommysmommy Plumbing 1 12-20-2011 09:12 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
