New Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2012, 06:40 PM   #1
new gas line
what size dose the line out side need to be from the meter to the house and what size inside the house. I am only supping a gas stove a tankless water heater
manni is offline   Reply With Quote
Old 07-08-2012, 07:50 PM   #2
not enough info. need combined BTU's of all apliances as well as length of longest run.
pardonme2711 is offline   Reply With Quote
Old 07-08-2012, 08:33 PM   #3
Rewards Points: 14,278
Not to be rude, but on this one if you have to ask then it would be best to get the gas compamy or a plumber do the hook ups for you.
Done wrong the best thing what would happen is they would not work, the worst would be your house blows up.
Old 07-08-2012, 08:58 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
I kinda agree with Joe, something like gas unless you’ve had prior experience, best left to certified Plumber.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 07-08-2012, 09:14 PM   #5
Rewards Points: 582
in most installations service line is 1 1/8 or 1 1/4 plastic.. inside 1" or 1 1/4" run to furnace or largest appaliance based on service line...with branches off that.... then we reduce down to handle the other demand for usage... what is your demand usage...
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
