Old 06-30-2010, 12:56 PM   #1
new gas grill with old gas lines
We had a weber gas grill and we just bought a brinkmann (1o years since last purchase). I wanted to move the grill from one side of a rectangle space to the nearest other side of a rectangular space. We turned off the gas and unhooked the old line. A plumber says we need to spend $300 to hook up the new grill. That seems awfully expensive.
pennie is offline   Reply With Quote
Old 06-30-2010, 03:38 PM   #2
Handyman
$300 for a safe gas line seems pretty cheap to me. I won't work on a gas line for love nor money, not because I don't think I could, but why take the risk, and anyway, in my area it's code to use a liscenced gas fitter. In fact, the box stores pulled the yellow flex gas pipes from their shelves a few years ago. You should ask the installer to explain the reasons for the cost and I'm sure he will be more than happy to tell you. Perhaps he is installing a quick release connection and an inline valve if you don't have one already. I think, also, that the 'shutoff' has to be immediately visible and easily accessed.
There's my 2 cents for what its worth..."ounce of prevention" thing
canadaclub is offline   Reply With Quote
Help with Nat. Gas Line for Grill albertgarrido Plumbing 7 06-29-2010 02:57 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
Painting A/C Fan Grill fritzycat1 Painting 3 09-09-2009 05:50 PM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 08:05 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
