New Furnace - Now Less Hot Water? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2010, 08:41 AM   #1
Question
new furnace - now less hot water?
we had a new furnace installed last week and they adjusted something having to do with our vent from the top of our hot water heater and now it seems that we have alot less hot water - always having to turn the shower handle further and further to get hot water - when previous we thought it was too hot and barely turned it to the hot side.
it's a new faucet assembly in the shower we had plumbed last spring.
any suggestions? our heater is already one notch from the hottest setting
qchawkfan is offline   Reply With Quote
Old 01-07-2010, 10:43 AM   #2
Rewards Points: 1,548
How is the hot water elsewhere in the house, say, at the kitchen sink? (You will need to run it for several minutes to mimic the usage of taking a shower.)
Adjusting the vent at the top of the water heater won't change the hot water although jostling an old tank might change the position of internal parts such as make the dip tube break off. (This latter condition will cause cold water to mix with hot water near the hot water outlet pipe.)
Old 01-10-2010, 05:31 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
what temp is heater set at?
plummen is offline   Reply With Quote
Old 01-10-2010, 07:15 PM   #4
no temp reading - it's one notch from the hottest - in the past few days it seems fine
Apollo Forced Air Furnace, leaking water sethfc HVAC 29 04-06-2010 02:31 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Converting from furnace to how water heater skittlzski Plumbing 2 05-16-2008 10:10 AM
