New Fluidmaster Pro 45K Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2009, 05:34 PM   #1
New Fluidmaster Pro 45K issue
IMy toilet started 'leaking' as evidenced by it running every few minutes. I replaced the flapper but got the same results. I then bought a new Fluidmaster Pro 45 K replacement kit and replaced both the fill and drain valve assemblies. Guess what, the flapper is still leaking!! The water slowly goes down to just the lip where the flapper should be sealing it, so
I know its leaking thru there. How can this be? The new flapper that came with it seems VERY flexible, maybe too flexible. Help!
mikefromcnj is offline   Reply With Quote
Old 12-17-2009, 02:14 AM   #2
duh who me
El Cheapo's Avatar
leaking down
You might try draining ALL the water from the tank get it dry ,hairdryer if necessary ,buy a tube of plumbers GOOP at home center, glue that seal over the rim where old flapper seated ,let it dry all nite apply GOOP generosly , it has worked for me .The sticky stuff on bottom of factory seal has to be super dry for it to work and it has to be mashed down over the seat just right
El Cheapo is offline   Reply With Quote
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Lennox G21Q issue gotzapped HVAC 2 11-25-2008 02:28 AM
