New Floor Drain In Existing Concrete Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2010, 04:21 PM   #1
New Floor Drain in Existing Concrete Floor
I need to cut in a floor drain in my unfinished basement. I want it to look clean once the concrete is patched. What is the best way to cut the concrete to have a clean edge? A friend of mine is a excavator and has a Stihl saw used to cut concrete pipe, but it makes lots of dust and the gas smell in the house would be horrendous! Any ideas?
Also, the floor drain (PVC) I bought has a 2" outlet. The existing main sewer is cast iron (either 4" or 6"). I was planning on using an 4or6"x2" wye, with a short piece of 4or6" pipe out of each end and a Fernco style fitting on each end. Does this seem right? How do I cut the existing cast iron pipe?
JPWMU is offline   Reply With Quote
Old 04-20-2010, 07:26 AM   #2
DIY staff
Rewards Points: 7,174
Cast iron is cut with a chain breaker--you can rent those.
Fernco's should work. You may need to go to a plumbing supply house for the right size.
Floor drains need a P-trap.
Clean cuts in concrete can be made with a circular saw with a diamond blade.
This can kill the saw.
---Mike--
Old 04-20-2010, 08:31 AM   #3
Mike,
Thanks for the info!!! The floor drain I bought is PVC and has a trap and plug built into it. It has a 2" outlet approximately 2" below the elevation of the rim of the drain. Will that work?
Old 04-21-2010, 06:51 AM   #4
DIY staff
That should be fine--Don't forget a floor drain needs a P-trap.--Mike--
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
concrete floor in bathroom cmt9000 Flooring 3 04-27-2009 07:37 PM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
