-   -   New Floor Drain in Existing Concrete Floor (http://www.diychatroom.com/f7/new-floor-drain-existing-concrete-floor-69389/)
JPWMU 04-19-2010 04:21 PM
I need to cut in a floor drain in my unfinished basement. I want it to look clean once the concrete is patched. What is the best way to cut the concrete to have a clean edge? A friend of mine is a excavator and has a Stihl saw used to cut concrete pipe, but it makes lots of dust and the gas smell in the house would be horrendous! Any ideas?
Also, the floor drain (PVC) I bought has a 2" outlet. The existing main sewer is cast iron (either 4" or 6"). I was planning on using an 4or6"x2" wye, with a short piece of 4or6" pipe out of each end and a Fernco style fitting on each end. Does this seem right? How do I cut the existing cast iron pipe?
oh'mike 04-20-2010 07:26 AM
Cast iron is cut with a chain breaker--you can rent those.
Fernco's should work. You may need to go to a plumbing supply house for the right size.
Floor drains need a P-trap.
Clean cuts in concrete can be made with a circular saw with a diamond blade.
This can kill the saw.
---Mike--
JPWMU 04-20-2010 08:31 AM
Mike,
Thanks for the info!!! The floor drain I bought is PVC and has a trap and plug built into it. It has a 2" outlet approximately 2" below the elevation of the rim of the drain. Will that work?
oh'mike 04-21-2010 06:51 AM
That should be fine--Don't forget a floor drain needs a P-trap.--Mike--
