New Flange On Top Of Old Too High - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2010, 08:12 PM   #1
New flange on top of old too high
We are replacing a 50-yr+ toilet. The original pipe and flange were one piece. The flange was broken and a plumber working at Home Depot told my husband he could install a new flange on top of the old one. But the new toilet won't go down flush with the floor. In fact, my husband can slide his fingers underneath the pedestal of the toilet. What should he do?
CurrieO'Brien is offline   Reply With Quote
Old 12-30-2010, 08:30 PM   #2
DIY staff
Rewards Points: 7,174
There are many kinds of flange repair pieces---I think he should have used a flat steel repair ring--
they are only 1/8 inch thick--I'll see if I can find a link--The Depot sells them--
Old 12-30-2010, 08:35 PM   #3
DIY staff
Google Image Result for http://www.terrylove.com/wc/toto/red_ring_03.jpg
Good luck--What kind did you use?
Old 12-30-2010, 08:38 PM   #4
Picky Plumber
If it's just broken where the bolts go, then use a spanner flange. This is a half-moon shaped piece that you'll stick your bolt through and slide beneath existing cast iron flange. Gotta love Home Depot, ehhh?
Plumber26 is offline   Reply With Quote
Old 12-30-2010, 08:52 PM   #5
DIY staff
Google toilet flange repair ring (images) You will see all types,including the spanner flange that Plumber26 mentioned--
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 05:37 PM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
Off Set- Broken-& Too High Flange GraciAnn Plumbing 13 04-10-2008 05:37 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 02:30 PM
