New Fiberglass Tub Uses OSB? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2010, 12:19 PM   #1
the Musigician
DangerMouse's Avatar
New fiberglass tub uses OSB?
This new fiberglass tub has " OSB built in along the bottom at the proper slant.
Is this OK for me to just run 2x4 frame under it? It seems more than strong enough from standing in it, but should I still 'box in' my frame and add mortar?
Our old tub has (believe it or not) simply a styrofoam block under it! It sags all over when you're in it and has a repaired crack at the drain....lol
Thanks!
DM
Old 08-13-2010, 07:49 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
unless the instructions say otherwise, I always put a mortar base under tubs and showers. No other wood is needed unless you want to build up the floor to save on mortar.
The Following User Says Thank You to TheEplumber For This Useful Post:
Thurman (06-08-2011)
Old 08-13-2010, 08:28 PM   #3
the Musigician
I got it at Habitat4Humanity ReStore... no instructions....
DM
Old 08-13-2010, 08:41 PM   #4
Electrician
Proby's Avatar
You put mortar under cast iron tubs too?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-13-2010, 08:51 PM   #5
the Musigician
Don't be a smart alec. If I build a solid frame under it, I see no need to put mortar under it.
Anything wrong with this?
DM
Old 08-13-2010, 09:18 PM   #6
Electrician
Proby's Avatar
Who is this in response to?
Old 08-13-2010, 09:39 PM   #7
Plumber
Rewards Points: 904
@ Proby, no I don't mortar cast iron. It won't creak like fiberglass
@ DM, IMO, most fiberglas tub bases should have mortar. It not only adds support, it keeps them from creaking and popping.
Old 08-13-2010, 09:43 PM   #8
Electrician
Proby's Avatar
Thanks!
Old 06-07-2011, 06:08 PM   #9
the Musigician
Just an update, the tub has been performing just fine these past months.
It's solid as a rock with the frame I put under it....
.....but I DID add shaped 2x4s up front where the OSB didn't quite make it to avoid any possible problems.
DM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 09:40 AM
fiberglass vs paper - revisited rtoni Building & Construction 3 03-25-2009 06:50 PM
Corrugated Fiberglass Roof theriver Roofing/Siding 1 09-16-2008 09:37 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 05:51 PM
