New Faucet & Pop Up Drain - Minor Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2013, 07:30 AM   #1
Rewards Points: 85
New faucet & pop up drain - Minor leak
I just installed a new faucet and pop up drain made by American Standard (Model: Serin) and there's a minor leak. There's a really small amount of water which is coming down into the drain body's threads.
I have installed the pop drain according to the manufacturer's instructions. To my surprise, the manufacturer doesn't require plumber putty below the flange. There's foam gasket installed under the flange (see image below).
I didn't put Teflon paste, plumber putty or caulk in between the bottom of the sink and the rubber gasket.
The lug nut was tighten enough. I stopped tightening the lug nut when the flange was flush with the sink.
To remedy the problem, what should I do ?
Add Teflon tape to the drain body where the lug nut is sitting ?
Add plumber putty below the flange ?
Add Teflon paste in between the bottom of the sink and the rubber gasket ?
Tight the lug nut even more ?
Any help would be really appreciated.
westbank is offline   Reply With Quote
Old 09-26-2013, 07:36 AM   #2
DIY staff
Rewards Points: 7,174
Some times there is a burr or other rough edge on the bottom hole of the sink--
Check for that---then add a dab of silicone to the rubber gasket and try it again---some use plumbers putty or even TFE paste
Old 09-26-2013, 08:17 AM   #3
Rewards Points: 85
Thanks Mike .
Would you also add some silicone caulk below the flange or the foam gasket should be enough ?
Old 09-26-2013, 09:10 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
All the pop ups I put in do not have the foam gasket which means I use putty- you might try that.
Another thing I do is- after the pop up body is in the drain hole I use pipe dope on the immediately exposed threads, only where the bottom gasket sits.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-26-2013), Javiles (09-29-2013)
Old 09-26-2013, 09:15 AM   #5
Rewards Points: 85
Thanks.
I'm not convinced by the foam gasket even though I'm sure it's doing its job.
I will put some pipe dope on the threads where the cone gasket sits. Do I have to put a lot ?
If it still leaks then I will add some putty under the flange (putty + foam gasket).
Thanks again.
Old 09-26-2013, 09:31 AM   #6
Plumber
Rewards Points: 452
My theory on the dope is that the gasket is not embedding into the threads and allowing water to pass down the threads.
So the dope is just a filler.
I have seen your problem often enough that this step has become almost second nature when I assemble pop ups
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
Javiles (09-29-2013), oh'mike (09-26-2013), westbank (09-26-2013)
Old 09-26-2013, 09:37 AM   #7
Rewards Points: 85
Makes sense because technically it's not possible to have a perfect seal between the gasket and the threads.
Question for you. If the water is coming down the threads, is it because the water is able to get in between the flange and the sink ? Just want to make sure the foam gasket is not letting water get in.
Thanks again. Much appreciated.
Old 09-26-2013, 05:04 PM   #8
Rewards Points: 85
What more appropriate: Pipe Joint Compound or Teflon-Thread Dope ? This is what's offered locally.
Old 09-26-2013, 06:12 PM   #9
Plumber
Rewards Points: 452
Non-setting teflon pipe dope
Sent from my iPhone using DIY Forum. Watch out for spell check
The Following User Says Thank You to TheEplumber For This Useful Post:
westbank (09-30-2013)
Old 09-26-2013, 08:34 PM   #10
Rewards Points: 582
yep there is no other way to install a pop up ..i use rectorseal ben sr
Old 09-29-2013, 11:52 PM   #11
Lord of Slums
Rewards Points: 1,974
I will only install metal pop ups. Is it leaking with the drain stopper open.
mj12 is offline   Reply With Quote
Old 09-30-2013, 10:27 AM   #12
Rewards Points: 85
A big thank you to TheEplumber. I have used Teflon pipe dope and the problem has been resolved.
Tags
bathroom , drain , faucet , leak , pop-up
Bathtub Drain Leak atm Plumbing 6 08-24-2013 08:48 PM
Proper Slope for Sump/Gutter Drain dankoos Plumbing 0 05-06-2013 01:59 PM
Need help with sink drain and tailpiece nordswe83 Plumbing 5 02-22-2013 12:08 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
