Installing a new 50 Gal electric water heater. I'm moving the unit to the back of the room. Do I need to install a vacuum breaker on the cold supply, I've heard yes and I've heard no.
Thanks! There was one on the old line to the water heater but I hadn't seen one before that. After seeing it, I asked around, heard some yeses and some nos. I defer all to your knowledge. Thanks Ron.
The purpose of a vacuum breaker at a water heater is, in the event extreme suction should be applied to the water system, for example a fire engine pumper fighting a fire down the street, the water heater tank doesn't collapse or implode.
They're only about $15. Of course you may need extra fittings which will likely double the cost. I think it's worth the expense. Especially since I believe you can use the same Vacuum Breaker over and over again.
Someone using Google to get plumbing do it yourself help.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
