#1 |
New DWV for detached garage apartment
I want to add a full bathroom to a detached garage apartment. The house and garage are both on a concrete slab fifteen feet apart in distance. 1. Can the new bathrooms drain/waste line tap into d/w lines of house with concrete slab? 2. Can new b/r d/w line tap in house sewer lines out side house, but seventy feet from garage? 3. Will new sewer lines be needed?
#2 |
call me E
The answers depend on where you live and the code used in your area. Your plumbing officials will have the answers.
#3 |
before proceeding call for general information about your plans a get approval 1st.... then you will have a clear direction to go in.....called plans & permits.....ben
#4 |
if your sewer is lower then bathtub/shower p-trap also you need to chip out all concrete to sewer and still have grade "slope". if you have a basement/crawl space and the pipes are lower then p-trap then YES! you are going to need PVC/ABS ETC.. "Waste pipe" "different state different code"
#5 | |
Super Moderator
New DWV for detached garage apartmentQuote:
What are you talking about? Did you even read the question?
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following 2 Users Say Thank You to oh'mike For This Useful Post: | LateralConcepts (12-08-2011), VIPlumber (12-08-2011) |
| Display Modes | |
| Expanding Garage INTO house (goodbye Den) | texaopian | Building & Construction | 16 | 11-07-2011 11:32 PM |
| Garage Insulation | yamster | Insulation | 0 | 07-01-2011 02:30 PM |
| Do I have a Fire Rating Issues with Attached Garage | Perry401 | Building & Construction | 4 | 04-26-2011 12:58 AM |
| Questions on Building apartment On top of existing detached garage | nsxman2001 | Building & Construction | 4 | 12-16-2008 05:36 PM |
