New Drains Take A Look - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2009, 02:40 AM   #1
Rewards Points: 12
new drains take a look
I am installing a bathroom downstairs I have attached a drawing of what I am doing in regards to the drains etc.
Does this look like it will work?
rrekih is offline   Reply With Quote
Old 06-07-2009, 06:57 AM   #2
How far away are the new fixtures from their main stack?? Code limits how far you can be without a revent.
Old 06-07-2009, 11:47 AM   #3
Rewards Points: 12
The main stack which is 4" is on one side of the house, the house is 19' wide.
So the fixtures are from 10' to 13' from the main 4" stack.
On the other side which picks up the kitchen sink there is a 2" stack after the kitchen sink.
Old 06-08-2009, 03:47 AM   #4
Looks good measurements are fine the structure of the drains looks good. good luck
Drain Cleaning - Blocked Drain Jetting and Drain Repair
jamesear is offline   Reply With Quote
Clogged Drains Willie5566 Plumbing 19 02-17-2009 08:45 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
replacing old galvanized drains drewhart Plumbing 18 07-20-2008 12:14 PM
drains are backing up eleven22 Plumbing 19 12-20-2007 09:21 AM
