New Drain Pipes To Old Drain Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2009, 02:17 PM   #1
new drain pipes to old drain pipes
Hello everyone, I am in need of some advice.
I am doing a bathroom remodel and I need to install new drain pipes from the bathtub,vanity and toilet into the old pipes.
I am also converting the shower into a laundry closet for a double stack. What would be the best way to do this?
Here are some pics of what I have to work with. The last picture is of the shower.TY
new drain pipes to old drain pipes-p3220014.jpg   new drain pipes to old drain pipes-p3220006.jpg   new drain pipes to old drain pipes-p3220016.jpg   new drain pipes to old drain pipes-p3220003.jpg
Twinvtec is offline   Reply With Quote
Old 03-25-2009, 03:33 PM   #2
Since the current material is cast iron with hubs, you can purchase "donuts" to transfer from cast to PVC. These fit into the hub for the transfer. This should make it easier for you to work with. Remember, shower drains are required to be 2" while tub/shower combinations only need to be 1-1/2". Check to make sure if your area now requires 2" for washer drains.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-25-2009, 03:44 PM   #3
new drain pipes to old pipes
Thank You for the reply, I have a question how do I get the old drain pipes off of the hub?
Old 03-25-2009, 04:14 PM   #4
"Sometimes" you can twist the pipe and break the lead loose. Other times, you may need to melt the lead out. Be careful doing this and do not allow any water contact with melting lead. Then you can pull out the oakum.
Old 03-25-2009, 04:39 PM   #5
new pipes to old pipes
Thank You for the reply.
Old 03-25-2009, 08:17 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Or....you can cut the pipe and leave the hubs alone. You would use a shielded coupling such as a Proflex by Fernco to make the transition from cast (or galvanized) to PVC.
JDC is offline   Reply With Quote
Old 03-26-2009, 08:15 PM   #7
pipes
Ok so I took the drain pipes out. I used a torch an melted the lead out.
should I take the last hub out? here are the pics.
new drain pipes to old drain pipes-p3260002.jpg   new drain pipes to old drain pipes-p3220007.jpg
Old 03-26-2009, 10:43 PM   #8
HVAC / Plumbing
Only if you need to or, it would help you on the tie in
kenmac is offline   Reply With Quote
Old 03-27-2009, 06:33 AM   #9
Household Handyman
Rewards Points: 1,408
I love working on those older homes with the old C.I. piping and the lath/plaster wall. I would not remove any more C.I. piping then necessary and would leave a hub to connect to. As posted there are "doughnut" type connectors to adapt the old C.I. to new PVC. Checking your local codes for compliance and pipe sizing would be a must do at this point also. Your posting of pictures certainly helps anyone understand where you are and where you are going at this point.
Old 03-27-2009, 07:18 AM   #10
Do you plan on replacing the supply lines with copper or PEX?
redline is offline   Reply With Quote
Old 03-27-2009, 11:47 AM   #11
old pipes new pipes
Yes I am going to be changing the supply lines, I would like to use pex knowing the cost related to using copper, but the previous owner started with copper so I am going to keep everything uniform. I am also going to run new electrical. This is going to be a complete bathroom remodel. I have pics of the way the bathroom looked before I started the demo. They are located at the project showcase forum under complete bathroom remodel. Thank You for your reply.
Old 03-27-2009, 02:41 PM   #12
Rewards Points: 562
If I were doing it,,,I would take out the large wye yet and replace with plastic to stool and new plastic wye for reducing down to 2". Reason is the 2"cast will tend to plug right where it joins the larger size.. Its rough and grabs on to soap scum and drained hair balls etc.. Plastic seldom if ever does!! Use purple goop and plumb away. its a short distance and prevention beats tearing things up for access later.
Other way is to tear out ALL cast including the stack,,how far up does it run(how many stories?) and how far down before it enters the ground?? How many more connections are on this stack?? AND are you willing to open enough walls to get to it all 'now'??
4just1don is offline   Reply With Quote
Old 03-27-2009, 02:50 PM   #13
The cast iron stack will quiet the water draining down it. PVC tends to allow the water draining to make sounds as it travels down.
Old 03-28-2009, 06:42 AM   #14
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
When using donuts to make the transition be sure to bevel your pvc (with a grinder, file, edge of the chop saw blade..whatever it takes) and to use plenty of pipe lube (aka "duck butter") Getting the pvc seated in the donut can be a real pain in the dexterior at times.
Old 04-07-2009, 07:16 PM   #15
Hud adapter
Here is what I used, a 2" hub adapter with the string and the plastic lead.
new drain pipes to old drain pipes-p4070022.jpg   new drain pipes to old drain pipes-p4070020.jpg
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 08:18 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Collapsed Drain Pipes Piney Plumbing 1 11-09-2006 04:46 AM
Where to find 2" square plastic drain pipes The_Flash Roofing/Siding 4 07-25-2005 07:35 AM
