New Drain Line Under Slab? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2012, 01:04 PM   #1
Rewards Points: 640
new drain line under slab?
I'm only asking this here because I don't know if I need to do some of this as DIY or not...
I am putting in a bar in the basement, it's about 4 ft from where an existing soil stack comes out of the slab.
I already have a general idea of where it is running, it goes diagonal directly infront of where I need the drain at about 5ft in front of where the PVC drain stub needs to come out of the slab
so in a triangle I have at one point to the right the soil stack 4 ft away (3" PVC) then 5ft directly infront of that we have where it is running under the slab to the outside line.
obviously, the slab needs cut and dug out. Is this something I have to do myself? I am getting a plumber to do the actual plumbing work since there are some code issues that need fixed with the original consturction at the same time. Or is this something that the plumbers generally take care of? I haven't called anyone out let to look at the job, just wanted to get an idea of what you guys usually do or expect to be done before hand. thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
Lowering basement slab and installing drain tile diybrad Concrete, Stone & Masonry 0 04-26-2012 09:36 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Sump Pump Drain line keeps freezing jerrylee Plumbing 5 02-25-2011 09:25 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
