New Drain Install In Slab Foundation, Options? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2010, 08:33 AM   #1
New drain install in slab foundation, options?
Hi, I am new to this forum but I am not new to DIY projects. I have a home built in the 50s on a monolithic slab foundation. The washing machine is currently in the kitchen and I want to move it about 25 ft to a utility room which has the dryer and hot water heater.
Currently there is no drain in that room and I need one for the washer. I was wondering if anyone has experience with this. I don't know what the best and cheapest route is to installing the new drain.
One plumber recommended a pit in the ground with a sump pump to the attic that meets up with my bathroom vent. However, I am not sure this is to code and if it would be too noisy.
I have also considered running a new line directly outside and tying in to my main but it is about 75 ft away.
I appreciate any advice on this topic. Thanks!
rhodesrt is offline   Reply With Quote
Old 12-02-2010, 08:56 AM   #2
www.No-Curb.com
JohnFRWhipple's Avatar
You have some digging to do...
I would shoot it outside and then hook up to your main line.
This will involve a lot of digging and landscaping.
You will have to vent this new line as well and make sure you include proper cleanouts as well.
Not a hard job - but one that involves a lot of back strength...
Good Luck
JohnFRWhipple is offline   Reply With Quote
Old 12-02-2010, 11:08 AM   #3
Something like this...
I have attached a picture of what I think you are talking about. Can I tie into the vent for the hot water heater which is near by?
Is there a specific way to include the cleanout in case I ever decide to add a bathroom nearby as well?
Thanks again
Drain pipes in slab acerunner Plumbing 0 10-04-2010 12:24 PM
Who jackhammers the slab when installing drain? tpagel Plumbing 5 09-08-2010 09:27 PM
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 09:20 PM
AC Coil Condensate Drain Options zootjeff HVAC 19 12-04-2009 04:19 AM
Tub Drain Install - What's The Trick? Ricky D Plumbing 2 06-09-2007 06:22 AM
