New Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2010, 07:22 PM   #16
Rewards Points: 1,658
Some people put pipe dope on plastic threads, others don't. If the nuts are hand tight (maybe a bit more with a tool if needed) none of your joints should leak. The washers do all the sealing for the most part.
bob22 is online now   Reply With Quote
Old 07-09-2010, 07:41 PM   #17
Licensed Master Plumber
No tape, No Putty, No Pipe dope. All the connections use compression washers.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-13-2010, 08:36 AM   #18
Owner
LateralConcepts's Avatar
Hey there! You probably already got it up and running. I just returned from a trip to Glacier National Park.
Looks good to me. I would just hook up the water and try running it. I typically don't use dope or tape on a p-trap. It works best just to run hot water and get the pvc nice and warm then get it as tight as you can by hand. If you don't have any leaks, you're good to go.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
