Old 07-08-2010, 01:15 PM   #1
new drain
Guys - looking for some help. I just pulled out my old bathroom vanity and put in a new one. The new one is a different size, and when i try and connect the drain, i'm a few inches out and can't fit the new down spout to the main line. I've popped a couple of pictures below which show it better. Any advice?
thanks,
Matt
mmhendrie is offline   Reply With Quote
Old 07-08-2010, 01:50 PM   #2
new drain
Loosen the joint at the stub out and turn everything connected to the wall upside down so that the black piece opens downward. Now connect that other U shaped piece at the bottom of one of the pictures to the black piece. The result should be a sideways S that you can move at the joints to meet your downward pipe from the sink. Good luck.
slomobile is offline   Reply With Quote
Old 07-08-2010, 02:32 PM   #3
new drain
nice idea - is something like that typically accepted by code?
Old 07-08-2010, 03:25 PM   #4
Owner
LateralConcepts's Avatar
new drain
What!? Don't think anyone understands nor, if I slightly understand, is that the proper way to do it.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 07-08-2010, 03:28 PM   #5
new drain
ok then - any other ideas out there?!
Old 07-08-2010, 03:35 PM   #6
Owner
new drain
mmhendrie -
I would suggest replacing the P-Trap all together since that one appears to have maybe leaked in the past, is mismatched, and sealed with something.
You'll need an 1 1/2 PVC extension tube to connect to the gray tube coming down from you sink
Then you'll need a new 1 1/2" PVC P-Trap - The new trap arm (that goes into the wall) you'll be able to cut to the appropriate length with a hack saw
Lateral
(208) 818-8241
Old 07-08-2010, 04:32 PM   #7
new drain
thanks! the grey downspout from the sink is 1 1/4" - how do I go from 1 1/4" to 1 1/2" on the pipes?
Old 07-08-2010, 04:54 PM   #8
Owner
new drain
Your new P-Trap kit should come with a 1 1/2" X 1 1/4" slip joint washer. It will look like thicker material than the others
EDIT - Forgot to tell you then, you'll need an 1 1/4" extension tube not 1 1/2".
Lateral
(208) 818-8241
The Following User Says Thank You to LateralConcepts For This Useful Post:
mmhendrie (07-08-2010)
Old 07-08-2010, 05:00 PM   #9
Owner
new drain
Is your old trap 1.5" or 1.25"?
Lateral
(208) 818-8241
Old 07-08-2010, 05:05 PM   #10
new drain
pretty sure the trap is 1.5"
Old 07-08-2010, 05:07 PM   #11
Owner
new drain
Ok so sounds like you've got it figured out?
Lateral
(208) 818-8241
Old 07-08-2010, 05:17 PM   #12
new drain
I think so - just have to wait to get home and give it all a try - much appreciate the help!!!
Old 07-08-2010, 05:21 PM   #13
Owner
new drain
No problem!
Parts List
  • 1 1/2" P-Trap Kit
  • 1 1/4" Extension Tube
Good luck
Lateral
(208) 818-8241
Old 07-08-2010, 06:37 PM   #14
new drain
on a post-it in my pocket, waiting for my drive home via Home Depot!
Old 07-08-2010, 11:50 PM   #15
new drain
ok, "Dry fitted" everything - picture below - two questions though
1. nowhere in my kit did it talk of using tape, putty, silicone etc. - do i need any of that?
2. i'm guessing the weakest point is where the reduction part is from 1 1/2" to 1 1/4", right above the u-bend. Given that the u-bend is typically full of water, does it make sense to move the reduction part up the pipe and use the 1 1/2" extension pipe, so the "weak spot" isn't the bit always under water? get what i mean? i know nothing about drains, so this might be something i'm just pulling out of the air!
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
