Old 04-25-2011, 12:59 AM   #1
New deeper kitchen sink install problem
I had an old sink about 5.5" deep and I replaced it with a Frankie 9.5" deep. Everything went well until I found out that the sink drains are towards the back of the sink. Now the insinkerator that I have does not have room to install.
The original sink had 2 separate P traps (one for the insinkerator and the other for the regular sink). Since the drain was in the middle, the insinkerator had no problems fitting in. Now with the drain in the back the insinkerator is able to install in the flange but there is no room for the P trap to install.
See picture below for details. I would prefer not to rip out the piping and install new. Any input is appreciated. Thanks.
jmalcolm is offline   Reply With Quote
Old 04-25-2011, 07:31 AM   #2
From the pic, the outlet from the disposal looks to be slightly higher than the wall connection. Slightly is close enough for drainage. With careful planning, you could connect a second trap on the disposal, or use a double sink connector for both.
Old 04-27-2011, 11:43 AM   #3
Just Bill thanks for the reply.
Problem is that there is no room at all for me to go into the outlet. The garbage disposal is sitting right against the outlet. I'm not able to put any kind of bend to route the pipe to the P trap.
Old 04-27-2011, 11:48 AM   #4
cap it and go in thru clean out
The older I get the better I was
Tags
drain, insinkerator, sink drain, sink installation
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
No hot water at kitchen sink allwet Plumbing 9 12-02-2009 08:37 AM
install sink in granite after basic install? damstenger Remodeling 3 02-06-2009 07:37 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
