New Dbl. Sink / DW / Disposal Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2008, 05:14 PM   #1
I completely gutted my kitchen and am putting in a new double sink, disposal and dishwasher. Can I run the D/W waste line into the disposal and the disposal out the waste pipe tied into both sinks without the use of an "air dam"?
You all have been really helpful in the past and could use some help again!
Kudos to all that help us "newbies"
Mary
mehaley is offline   Reply With Quote
Old 08-03-2008, 05:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
An "air gap" may be required by code in your local jurisdiction, so you need to check with your Building Inspection Department regarding that.
If an an air gap is not required, you can loop the dw drain hose over the dw, connect it to the disposal (don't forget to knock out the disposal "knock-out plug" with a screwdriver and hammer), and then drain the disposal through the trap to the drain pipe.
It will work either way, but it is safer to have an air gap to prevent dirty dw drain water from flowing back into the dw in case of a clog.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-03-2008, 06:04 PM   #3
Thanks!!!
Old 08-05-2008, 08:28 AM   #4
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
As an alternate, to minimize noise and the possibility of disposal waste entering the DW drain line, you can use a "Wye tailpiece" under the other side of the sink to connect the DW drain. These are readily available at Home Depot or Lowe's.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-05-2008, 08:43 AM   #5
That is EXACTLY what I did in my own home - I did not hook it in to the disposal at all - I brought the D/W waste tube up and around and back down to the waste pipe off the sink on the other side. I figured bringing the waste tube in an upward position and then back down would serve as a de factor air dam.
However, this is a property that I am flipping and don't want any issues with a home inspector.
So - it is OK to do that??
Thanks,
Mary
Old 08-05-2008, 09:02 AM   #6
mstplumber's Avatar
Rewards Points: 150
It really depends on your local jurisdiction. Here in Atlanta an air gap is not required. If you want to "arm yourself" against a home inspector, so to speak, call your local government Building Inspection department and ask them what code they enforce. I have found that some private home inspectors will cite code violations from an incorrect code. This is not to say that they aren't competent, just that the issue is sometimes confusing.
For example, in Georgia some phases of residential construction is governed by the International Residential Code (IRC), which has a section addressing plumbing. Georgia Plumbing installations, however, are governed b y the International Plumbing Code (IPC). I just mention this to show how confusing it can be.
If I were in your situation, I would loop the drain to the top of the cabinet, use the "y" tailpiece and forget it. If a home inspector flags it you can change it then.
You might want to check out some recently finished homes in the area and see how the plumber did it. If they are past the inspection process the plumbing has been approved.
Mstplumber
Old 08-05-2008, 10:05 AM   #7
Registered User
Termite's Avatar
I'm finding that more and more dishwashers have an itegral air gap, thereby making a drain loop/gap redundant. You might check your manufacturer's installation instructions and keep them handy for the inspector to look at if that's the case.
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
Sink Installation - Please help again! iOsiris Plumbing 17 08-08-2007 06:14 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 12:23 AM
Disposal & Sink w/back set drain??? Kathy Plumbing 2 03-04-2007 02:48 PM
Double sink drainage installation JeffBPaarsa Plumbing 2 11-23-2006 09:08 AM
