New Construction - Dwv Tub/toilet Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2013, 09:40 PM   #16
Rewards Points: 636
correct t for the arm but a wye for the horizontal where it turns up to go into wall as the drain vent combo.
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-01-2013, 09:45 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 562
Ah, I thought you were talking about the dirty arm.... I guess I need to stop watching Duck Dynasty while on DIY Chatroom...
Old 03-01-2013, 09:55 PM   #18
Master Plumber
Javiles's Avatar
Rewards Points: 994
Are you kidding that show gives us all hope.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-01-2013, 10:19 PM   #19
I thought you could use tees for the sinks as long as they are vertical? Should I replace them all with y's?
Overkill but I'm using 2" on all drains.
I'll vent the tub up the outside wall and tie back into the stack for a better vent. Should I then a run a 3x3x2 wye before the toilet to drain the tub water versus inline after the toilet as drawn?
kevinrx1 is offline   Reply With Quote
Old 03-01-2013, 10:43 PM   #20
Plumber
Rewards Points: 562
I think I messed you up-- You need to use a tee when tying the horizontal sink arm into the vent. The toilet vent should connect to the main drain with a wye/45- just remember- vertical to horizontal is always a wye(with few exceptions)
The tub vent can go through the roof by itself.
My code has the 3 x 2 wye downstream of the toilet vent.
Old 03-01-2013, 10:48 PM   #21
Got it- thank you!
Old 03-02-2013, 04:08 PM   #22
Rewards Points: 1,868
hey ghostmaker why does the tub need a separate vent when a 2 inch is allowed 8 feet to vent under ipc
As he has it drawn the tub has no vent so when the toilet flushes it will pull the water from the tub trap and allow sewer gas into the house. He may not pull the trap on the first flush but each flush will cause a rocking motion in the liquid trap seal. This motion will eventually cause a loss of seal allowing sewer gas into your living area.
It's basic fluid dynamics. A toilet is a large surge of water and as that surge enters the pipe an air source is needed.
The second reason is as he has it drawn it will not meet the Ohio plumbing code. The object of plumbing is to install it in a way that protects the trap seals. The code is designed from past mistakes and is constantly revised to make corrections. Plumbing in the USA is over 100 years of knowledge accumulated from failures.
You will find if you pull the permits most if not all inspectors will be willing to come out and help you lay out the job. Our job is to make sure an installation is done so your house and largest asset you may own is protected. We are not here to cause you problems but to guide you on the proper way to install a particular installation to meet the code.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
jaydevries (03-03-2013)
Old 03-03-2013, 12:38 AM   #23
Rewards Points: 636
hey ghost just so i learn. if you put the tub on a wye between the sink/wet vent combo and the toilet and it is a 2 inch going to tub and is within 8 feet of wet vent would that meet code
Old 03-03-2013, 01:21 PM   #24
I re-drew it with proposed changes. Because it is a whirlpool tub with a deck/pier it will not be possible to vent straight up or inbetween the toilet and tub. I can go up the outside wall and revent if I have to but was wondering if the new picture would also work downstream? It is just under 8 feet center to center.
new construction - dwv tub/toilet question-20130303_135908-1-.jpg
Roof Venting Question - Urgent michi098 Roofing/Siding 19 03-15-2013 01:13 PM
interior construction project question kindofsudden Building & Construction 5 11-07-2012 09:51 AM
Best practice question - Exhausting bathrooms fans in new construction. rbartram HVAC 5 01-21-2011 06:26 AM
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 04:52 PM
Question on wall construction wood warrior Building & Construction 1 04-24-2008 11:25 AM
