New Construction - Dwv Tub/toilet Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2013, 07:52 PM   #1
new construction - dwv tub/toilet question
Hi everyone,
I have a new construction and want to double-check the current setup of a second story tub/shower/sink combo. The layout has the tub on the opposite wall but inline with the toilet so here is what I did initially from left to right ...
2" P-Trap - 2" pipe - 2" to 3" adapter - 3" pipe - 3" horizontal sanitary tee (up for 3" toilet) - 3" pipe - 3" vertical sanitary tee (up for for 3" vent and down for 3" waste).
Distance from the tub drain to the vent is 7 feet.
Is it permissable to run inline horizontally from the tub to the toilet before the vent?
A better solution?
Thanks!
Kevin - new member
kevinrx1 is offline   Reply With Quote
Old 03-01-2013, 07:59 PM   #2
Rewards Points: 636
can you draw it some sizes and measurements and then post some pics and if you want it to local code you will have to give your location
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-01-2013, 08:21 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
You're description doesn't make sense
Old 03-01-2013, 08:31 PM   #4
here's a quick drawing - thanks!
new construction - dwv tub/toilet question-dwv.jpg
Old 03-01-2013, 08:37 PM   #5
Northeast Ohio - sorry...
Old 03-01-2013, 09:03 PM   #6
Rewards Points: 636
where is you sink at
Old 03-01-2013, 09:04 PM   #7
Rewards Points: 636
you need to use a wye and a 45 if you have the room or lay a wye on its side and then use a 3x4 toilet 90 for toilet
Old 03-01-2013, 09:09 PM   #8
I didn't draw it but the sink is directly off the 3" vent stack
Old 03-01-2013, 09:10 PM   #9
Rewards Points: 1,772
You need to vent your tub trap. Also a y fitting is required for the toilet. You cannot drain any material into a TEE fitting as shown. You also should pull a permit as required for your construction so your home will not be condemned in the future. Ohio is very strict about building codes especially northern Ohio where I inspect for a county.
Old 03-01-2013, 09:14 PM   #10
thanks jaydevries - as long as I reroute with the wye and 45 it then the tub should be okay vent-wise? I just didn't want to revent up and over the outside wall to tie the tub back into the stack. I appreciate the advice.
Old 03-01-2013, 09:23 PM   #11
I have all the permits - unfortunately the original plans you have sometimes change due to the final design of the home. I'm seeking advice and won't have it inspected until it's perfect.
Old 03-01-2013, 09:55 PM   #12
Rewards Points: 636
hey ghostmaker why does the tub need a separate vent when a 2 inch is allowed 8 feet to vent under ipc
Old 03-01-2013, 10:16 PM   #13
Not legal any state in the USA that I'm aware of many things wrong. Definitely no way in massachusetts
joes plumbing is offline   Reply With Quote
Old 03-01-2013, 10:19 PM   #14
Rewards Points: 636
if the sink is on the vent stack then that would have to be a wye also
Old 03-01-2013, 10:31 PM   #15
Plumber
Rewards Points: 452
Tee is the way we have to do it for fixture arms.
And why 2" to the tub or is it a shower?
Roof Venting Question - Urgent michi098 Roofing/Siding 19 03-15-2013 02:13 PM
interior construction project question kindofsudden Building & Construction 5 11-07-2012 10:51 AM
Best practice question - Exhausting bathrooms fans in new construction. rbartram HVAC 5 01-21-2011 07:26 AM
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 05:52 PM
Question on wall construction wood warrior Building & Construction 1 04-24-2008 12:25 PM
