-   -   new construction - dwv tub/toilet question (http://www.diychatroom.com/f7/new-construction-dwv-tub-toilet-question-173329/)
kevinrx1 03-01-2013 06:52 PM
Hi everyone,
I have a new construction and want to double-check the current setup of a second story tub/shower/sink combo. The layout has the tub on the opposite wall but inline with the toilet so here is what I did initially from left to right ...
2" P-Trap - 2" pipe - 2" to 3" adapter - 3" pipe - 3" horizontal sanitary tee (up for 3" toilet) - 3" pipe - 3" vertical sanitary tee (up for for 3" vent and down for 3" waste).
Distance from the tub drain to the vent is 7 feet.
Is it permissable to run inline horizontally from the tub to the toilet before the vent?
A better solution?
Thanks!
Kevin - new member
jaydevries 03-01-2013 06:59 PM
can you draw it some sizes and measurements and then post some pics and if you want it to local code you will have to give your location
TheEplumber 03-01-2013 07:21 PM
199 Attachment(s)
You're description doesn't make sense
kevinrx1 03-01-2013 07:31 PM
1 Attachment(s)
here's a quick drawing - thanks!
kevinrx1 03-01-2013 07:37 PM
Northeast Ohio - sorry...
jaydevries 03-01-2013 08:03 PM
where is you sink at
jaydevries 03-01-2013 08:04 PM
you need to use a wye and a 45 if you have the room or lay a wye on its side and then use a 3x4 toilet 90 for toilet
kevinrx1 03-01-2013 08:09 PM
I didn't draw it but the sink is directly off the 3" vent stack
Ghostmaker 03-01-2013 08:10 PM
You need to vent your tub trap. Also a y fitting is required for the toilet. You cannot drain any material into a TEE fitting as shown. You also should pull a permit as required for your construction so your home will not be condemned in the future. Ohio is very strict about building codes especially northern Ohio where I inspect for a county.
kevinrx1 03-01-2013 08:14 PM
thanks jaydevries - as long as I reroute with the wye and 45 it then the tub should be okay vent-wise? I just didn't want to revent up and over the outside wall to tie the tub back into the stack. I appreciate the advice.
kevinrx1 03-01-2013 08:23 PM
I have all the permits - unfortunately the original plans you have sometimes change due to the final design of the home. I'm seeking advice and won't have it inspected until it's perfect.
jaydevries 03-01-2013 08:55 PM
hey ghostmaker why does the tub need a separate vent when a 2 inch is allowed 8 feet to vent under ipc
joes plumbing 03-01-2013 09:16 PM
Not legal any state in the USA that I'm aware of many things wrong. Definitely no way in massachusetts
jaydevries 03-01-2013 09:19 PM
if the sink is on the vent stack then that would have to be a wye also
TheEplumber 03-01-2013 09:31 PM
199 Attachment(s)
Tee is the way we have to do it for fixture arms.
And why 2" to the tub or is it a shower?
