Old 10-16-2009, 08:39 PM   #1
New House Newbie
Default New Compression Shut Off Valve for Toilet Leaking
I am installing a new toilet in a new bathroom and I bought a compression type fitting/valve to install on the copper stub out of my wall. I have now installed 2 valve, both of which leak from the valve. Water is coming out of the compression nut on the wall side of the valve. I assume the compression ferrel is not tight enough. I have turned it per the directions, but do not want to go too much more in fear of overtightening it. One question is that I thread taped the threads on the valve; would that cause the compression nut not to compress the ferrel as it should? I do not want to try anything more until I hear back on some advice.
C_J_GO is offline   Reply With Quote
Old 10-16-2009, 08:41 PM   #2
New House Newbie
A little more info...
My first valve I installed leaked and I kept tightening the nut down, eventually tightening it too much as when I removed the valve, the ferrel was indented into the copper pipe. Thus I have not tightened the second as much. I cut off the back section of copper pipe before installing the second valve, but I do not have much more I can cut off. Suggestions?
Old 10-16-2009, 08:45 PM   #3
Residential Contractor
Until the plumbers can get to your question for a more definite answer, it has always been my understanding that putting teflon tape on a compression fitting can actually cause it to leak.
I have found that sometimes you have to give it pretty good torque to get them on correctly, but let's see what the pro's say.
rselectric1 is offline   Reply With Quote
Old 10-16-2009, 08:54 PM   #4
Master Plumber/Mechanical
Tape is not required for compression fittings
Clean off the tape and try again
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-17-2009, 08:57 AM   #5
JDC
Plumbing Contractor
JDC's Avatar
Agreed. Get rid of the tape. When I have a stubborn one I'll put a light coating of pipe dope on the ferrule, but even that isnt required. The ferrule makes the seal, not the threads.
JDC is offline   Reply With Quote
Old 10-18-2009, 10:15 AM   #6
Same as everybody else remove all tape. Sometimes I put a little veg oil on my finger and run it around the copper and ferrule then tighten it, watch out you don't over tighten a common mistake, tighter is not always better in this circumstance.
Make it snug turn water on slow watch for leaks tighten little more if leak present.
SULTINI is offline   Reply With Quote
Old 10-22-2009, 05:30 PM   #7
New House Newbie
Yep, got rid of the tape and it has been dry for 2 days now. Thanks for all the help.
More On This Topic
We're hooking up the angle stops for the water supply to the sink right now. I've got the cold water side done and now I'm going to do the hot water side. I've got to cut this cap off the copper pipe and then fit the valve onto the pipe, so, let's go... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and we’re installing a new dishwasher. The water inlet, which is, everything’s located on the bottom. You just want to take some Teflon tape and... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
Last but not least to set the toilet is the supply line. The braided supply lines come in different lengths, and when we're too close to the valve, and I 'm afraid of kinking it, I go with the longer supply line and loop it. Now we just need a pair of... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through our reassembly process. I purchase this complete repair kit from the hardware store now this includes all of the basic workings for replacing the guts of your... Read More »
HOW TO diagnose gas valve problems Nestor_Kelebay How To Guides 3 08-18-2009 12:40 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 01:08 AM
Re-using compression nut and sleeve on another brand of shut off valve? DIYGST Plumbing 4 01-19-2009 02:44 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 01:16 PM
Washing Machine compression valve leaking...HELP! tmcguirk Plumbing 12 04-17-2008 10:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
