Old 08-30-2011, 09:05 AM   #1
New closet flange over old?
Hello all
This is my first foray into plumbing, so any help would be appreciated.
It looks like the previous owner cut off the ring of the old closet flange, cut off the barrel of the new closest flange, and use some leftover wax to create a seal. Leaking ensued and here I am with a 1'x1' hole in the floor.
I bought a new 4x3 closet flange but I'm not sure if it will sit right inside the old old closet flange. Is it possible to cut the old flange out of the elbow and install new? Is there some other way?
Thanks for the help!
shazapple is offline   Reply With Quote
Old 08-30-2011, 06:32 PM   #2
Super Moderator
What kind of pipe---Iron or plastic? Can't tell from the picture.
Old 08-30-2011, 07:22 PM   #3
call me E
TheEplumber's Avatar
I'd say its ABS- you can see the hubs.
If I was repairing this, I'd replace it all back to the stack. that 90 looks too hacked up to save.
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (08-30-2011)
Old 08-30-2011, 08:01 PM   #4
Super Moderator
Exactly--you had a failure with someone elses 'fix up patch job'--best to replace with new.
Old 08-31-2011, 09:39 AM   #5
I cut off the old old flange at the elbow and scored the junction of the remaining flange with a knife. Then I used a flathead screwdriver to peel the remaining flange off the elbow (not as easy as some may say). The knife scoring helped guide the peeling. I sanded, cleaned, and glued the new closet flange into place.
I bought a Caroma toilet with the offset outlet. It's nice because the outlet is attached to the flange separate from the toilet, so you can check for a good fit.
If I were to do this again I would cut off everything as mentioned by TheEPlumbers, and then use it to beat the previous owner
Closet flange too high dank Plumbing 8 04-14-2010 02:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 09:22 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
