New Bathtub Creaks When Standing In It - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2013, 02:41 PM   #1
Rewards Points: 150
New bathtub creaks when standing in it
This is a tub with styrofoam base. It only does it when you step on the back end. I noticed the stringer I put for the back doesnt make contact with the tub but Im not sure if I was supposed to put a stringer for the back anyway. Its a steel tub. With tubs with styrofoam are you not supposed to use any mortar to place them in?
Arsinek is offline   Reply With Quote
Old 03-31-2013, 04:24 PM   #2
Roofmaster
Rewards Points: 2,210
By stringer do you mean a ledger strip for support? Did the installation instructions call for Mortar?
Old 03-31-2013, 04:28 PM   #3
DIY staff
Rewards Points: 7,174
I use mortar--instructions or not---
jaydevries (04-03-2013)
Old 03-31-2013, 04:29 PM   #4
Rewards Points: 150
Ya, the support thing, instructions say stringer. Heres the instructions, not much to them..... http://www.bootz.com/sites/default/f...0for%20Web.pdf
Old 03-31-2013, 04:29 PM   #5
Rewards Points: 150
Even if its steel with styrofoam base?
Old 03-31-2013, 05:22 PM   #6
DIY staff
Yep---I would have---just a thin bed--enough to make sure there is full contact.
Mainly I use cast iron tubs---these steel tubs are flexible---so the cast iron is worth the extra expense to avoid problems like this.
Old 03-31-2013, 06:57 PM   #7
Rewards Points: 150
Is the tub supposed to make contact with the stringer, resting on it, or is it supposed to be right above it?
Old 03-31-2013, 07:11 PM   #8
DIY staff
It rests on the stringer----some times they must be notched to clear some obstruction on the tub---
Old 03-31-2013, 07:16 PM   #9
Rewards Points: 1,958
Pull it out put a stringer in as instructed. Also do not forget the roofing nails above the tub lip.
Ghostmaker is online now   Reply With Quote
Old 03-31-2013, 11:15 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Hope you put something between that tub and Morter.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-03-2013, 05:44 PM   #11
Sand
Sand will also act as a base and easily done
plumbthat is offline   Reply With Quote
Old 04-03-2013, 05:51 PM   #12
Rewards Points: 636
when i first started we would use sand but we found out long term if tub flexes it will disperse sand to different location and then you still end up with stress cracks
mortar all the way unless it is full ridgidized foam bottom and floor is level then a few tubes of silicone between to prevent squeaking
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Standing Water/Overflow After Snaking 7 VII 7 Plumbing 25 07-10-2013 02:14 PM
Can a standing pilot use electronic ignition? richapple HVAC 20 11-26-2012 11:45 PM
How to get a switch to power ON/OFF a standing lamp? Metallo Electrical 8 02-14-2011 04:25 PM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Standing liquid in cleanout TheOldMan Plumbing 1 12-11-2008 02:15 PM
