New Bathroom Sink To Low - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2013, 03:33 PM   #1
New bathroom sink to low
I just installed a granite top in my bathroom and the new sink is about inch too deep. I also installed new faucets that come with its own color coated drain. After cutting the new drain pipe as short as I can, the P-trap is about an inch lower then the pipe coming out of the wall. I know three solutions are to either lower the pipe in the wall, or raise the granite top, or turn the P-trap around. I don't want to do either of 1st two and I've read you should never reverse the P-trap. I included two photos. The first picture is of gap between the P-trap and the pipe coming from the wall. I can actually get it closer then the photo shows, but you can get the point.
The 2nd photo shows about a 2 inch extension that I put between the pipe coming from the wall and the P-trap. Is this a valid configuration? Everything seems to work fine.
billg13 is offline   Reply With Quote
Old 03-30-2013, 03:42 PM   #2
Rewards Points: 14,312
If it's draining ok then just leave it.
Old 03-30-2013, 04:17 PM   #3
Roofmaster
Rewards Points: 2,210
It's OK but why didn't you just cut the tailpiece shorter?????
PS Why is there a dishwasher tailpiece in the bathroom????? and whats it connected to??????
The Following User Says Thank You to jagans For This Useful Post:
mj12 (03-30-2013)
Old 03-30-2013, 04:55 PM   #4
I was wondering the same thing.
Sometimes on here I've seen condinsate drains running to sinks for some odd reason.
Old 03-30-2013, 05:10 PM   #5
Lord of Slums
Rewards Points: 1,974
As Joe said, just leave it.
mj12 is offline   Reply With Quote
Old 03-30-2013, 05:34 PM   #6
Rewards Points: 582
if it works leave it ..even if its not right....which it isn't...ben sr
Old 03-30-2013, 05:40 PM   #7
Roofmaster
Kind of looks like its leaking at the escutcheon, but maybe not. You may want to fill the sink, and pull the plug to put a real test on it.
Old 03-30-2013, 05:51 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
If this is a bathroom sink...then what is the rubber hose on the side for?
ddawg16 is online now   Reply With Quote
Old 03-30-2013, 06:08 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 912
Condensate- either roof top or attic unit- that's my guess.
I hope the OP shortened the 11/4" tailpiece so it doesn't block the wye branch
Old 03-30-2013, 06:10 PM   #10
Thanks everyone for responding so quickly.
The hose coming in from the right side if the picture is my AC condensation drain from the attic. The sink to the left of this one, has one also. Seems like this is very common in Texas.
While I can cut that tailpiece a little more, it will make the gap closer but it will still put the P-Trap about 1/2 inch from the pipe coming from the wall. I know the picture makes it look like it will fit if I cut that tailpipe more, but it wouldn't. I did fill the sink all the way and then let it drain and there is still no leaks.
The escutcheon has some rust on it but that has been there a while. But thanks for pointing that out. I'll look into it.
I see that Ben's plumbing said it isn't a correct configuration but leave it if it works. That was my main question about if it is correct. I'm thinking it's not because the water has to travel higher from the bottom of the P-trap then it was intended to do. I think the P-Trap designed is such that it only has to ravel a short way up to exit the pipe coming out of the wall. Once you start extending that, then the water has to travel further up hill, which should not normally work very well, correct?
Old 03-30-2013, 06:15 PM   #11
Plumber
Rewards Points: 912
Maximum trap seal is 4". Thats not an arbitrary figure they came up with either. There is reasoning behind it- But you'll be OK with what you have- You'll have better chance of saving your wife ring when it goes down the drain
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (03-30-2013)
Old 03-30-2013, 10:32 PM   #12
Rewards Points: 582
its not that big of a deal.....it will work fine....move on to the next project ben sr
Tricky bathroom remodel - any suggestions? mannewskie Remodeling 8 04-03-2013 06:26 PM
Running water does not go down in upstairs bathroom sink :( dnharp Plumbing 3 02-17-2013 04:37 PM
Help with Bathroom Sink Supply Line RudySands Plumbing 3 02-07-2013 07:46 PM
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 01:13 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
