Old 08-07-2012, 10:41 AM   #1
new bathroom sink drain leaks
I installed a new vanity top in bathroom yesterday. It got leak just at top of tailpiece. Not sure where is wrong. I took a picture and attached here.
pang is offline   Reply With Quote
Old 08-07-2012, 11:24 AM   #2
Was there a gasket under the lip inside the sink where the pop up slides in?
There needed to be a gasket or plumbers puddy.
If there was then try applying some teflon pipe dope to the threads where that nut is under that big rubber washer.
pang (08-08-2012)
Old 08-07-2012, 09:30 PM   #3
Smile
I wrap some teflon tapes around threads. It make leak nearly stop, but still tiny leak there :-( does putty work better on threads?
Old 08-07-2012, 09:39 PM   #4
call me E
TheEplumber's Avatar
I hate plastic tailpieces
Get a small can of this. IMO works better then tape or putty
http://www.homedepot.com/buy/plumbin...l#.UCHCdvZlRZc
Apply it to all mating surfaces and threads.
The Following User Says Thank You to TheEplumber For This Useful Post:
pang (08-08-2012)
Old 08-07-2012, 10:06 PM   #5
Doing it myself
Alan's Avatar
I hate those plastic pieces of s$%^ as well.
More than likely it's not the tailpiece but it's coming down the threads between the gasket and the popup assembly.
What we do :
1 : Lower the nut all the way down
2 : lower the gasket all the way down
3 : run a heavy bead of DAP 50 year caulking around the threads just above the gasket
4 : Re tighten the nut, and the gasket will push the DAP into the threads all the way up.
Journeyman Plumber
Alan is online now   Reply With Quote
The Following 2 Users Say Thank You to Alan For This Useful Post:
pang (08-08-2012), TheEplumber (08-07-2012)
Old 08-08-2012, 10:57 AM   #6
It is the simplest way and make lot of sense, I will try it. Thx!
What we do :
sink drain exterior wall iskyfly Plumbing 11 02-04-2012 07:38 PM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 10:52 AM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 08:52 PM
Bathroom sink drain extension Docfletcher Plumbing 2 12-10-2008 11:30 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
